audioholic
not a moderator
Im going to claim laziness here by not looking up the specs of the box/system. You wont hurt your equipment by playing with the lpf, and the best setting is based on many things. Again, just play with the settings until you find what sounds best to you.The box is the vented mtx thunder box that came with the sub
As for the hpf, unless the box is tuned very high, a hpf of 20hz should work fine. If you run into issues with over excursion of the woofer, adjust the hpf higher (unlikely).
---------- Post added at 08:34 PM ---------- Previous post was at 08:33 PM ----------
Good to be back.Wow...haven't seen you post on here like...forever!
