how to change vehicle specific box from sealed to ported
  • 6
fatboyracing
Owensboro KY
Okay I am in a dilemma I have a 2010 avalanche I can't remove the seat or add a box in the rear.
I have a great front stage but the sub stage is just week.
My only option was a pre built sealed box I am not happy with how it sounds I am running a sundown sd2-10 due to clearance
box info 0.96 Total cu.ft and 5 7/16" Mounting Depth
Height 5 5/8" x Width 44 1/8" x Top Depth 16 1/2" x Bottom Depth 16 1/2"
I know that this sub could sound better ported I have no clue how to port a pre built box I have always built boxes with slotted ports having room but I have no way to fit anything else
do I have any options such as adding like a areo port if so where do I even began I would love to wind up somewhere around 33 hz
here is a link to the box I have if this helps
Amazon.com : Audio Enhancers AV96SC10 Avalanche and Escalade Subwoofer Box, Carpeted Finish : Vehicle Subwoofer Boxes : Car Electronics
I was in your situation once... with a 00 ext cab silverado... then i removed the backseat and now its a box (the backrest is still there and you can sit on it, it's just not soft obviously).
if you want the response i think i know you want, you're going to have to do more than add a port to that box. honestly i dont think you even have enough volume for a properly ported box with that sub, but maybe some other members can chime in and i could be wrong..
ya that what I thought I cant give up the seat my kids are always in the truck
I think I am just going to try a 2in aero port I might not like it but it is worth a shot I don't like what I have now
you could try modelling that enclosure in winISD or theres some online port calculators available. it'd give you a good idea of what your optimum port size would be for that sub in that volume, and would be better than just throwing a port in and seeing what happens
We have went to the junk yard, bought a whole rear seat. strip the upholstery and padding. Build a down firing ported enclosure to replace seat bottom frame. Add OEM padding and upholstery to it. just make it strong. I can usually get enough ^ft to run a 12 or 15 that way ...
If you’re logged in the word censor is now turned off. Happy Holidays everyone!
821
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
Man.. thats nice you guys got that one figured out. Sweet. Ill have to remember this
It may be the sizing of the images.on my ddx396,thats what it came down to.the sizing.said the same thing as yours.unsupported files.took me a...
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
    Jun 15, 2024
    Jun 15, 2024
