how should i run my grounds
Ununpentium
ive got 2 amps, both PPI's
1) PPI PCX 4125 ... 1000W 100A max draw
2) PPI PCX 2400 ... 1600W 160A max draw
ive been to quite a few moblie audio shops and some of them said that these amps can be grounded right in the trunk with the 4 gauge ground wires comming out of the amp, and others said you should run all of the 4 gauge ground wires into a distribution block and back out of the block with a 1/0 running back to the battery.
who is right?
doesnt it go by how big the system is that you would ground it using one of these methods?
thanx for the help!//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I run multiple amps and have 4ga ground running from the amps to a distribution block, and a short length (about 2 ft) of 1/0ga running from the block to a spot under my rear seat, using a nice Stinger grounding plate. No problems.
I'm planning on using a 1/0 Cable for my main ground to the trunk. Using a streetwires grounding block(looks like a triangle with 3 screwholes) From that the 1/0 wire is going into a Stinger HPM Distribution block where everything will tie into. It has connections for 4ga and 8ga cables.
Gonna do this for my grounds
Car -> Dielectric Grease -> Streetwires Ground Block -> Dielectric Grease -> Streetwires 1/0 Cable -> Dielectric Grease -> Stringer HPM Distribution Block -> AMPs/Computer/Whatnot
For my Power i have a stingpro digital ANL fuse holder thats going in the engine bay. From there i go 1/0 to the trunk to a Stinger Midi/Mini ANL digital fused distribution block (Eventually. for now I'm going to use a knukoncepz mini fuse block since the Stinger is roughly $100)
I'm thinking about putting a Circuit Breaker in the engine bay. Not so much for protection. More for an easy way to cut power to the entire system.
Ununpentium
Ununpentium
auburn, ma
Ruffy
