How Should i go about wirring it all up??
AboutTreeFiddy
I have a 2 ohm Kenwood KAC-929 amp, and a 4 ohm Skar 10" Dual Voice coil. I know I know its skar but hey. so anyways my question is, what would be the best and more efficient way utilizing all of the amps power? would I benefit from bridging the subwoofer and from the sub to the positive and negative on the amp? or should I bridge the amp as well?
Easy for ya. Wire up the coils + to + and - to -. Then do the same to the amp, in bridged mode. Will get ya the most output from that amp. This is called wired in parallel.
Thanks man! That's what I figured would be the best route. But I wanted to clarify first ha. I appreciate it!
:) In Electrical Engineering terminology, yes! ;-)
John Kuthe...
The CT's are nice, That Sundown is a a frik'n beast!
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
825
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
958
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
AboutTreeFiddy
AboutTreeFiddy
Indiana
Boomin_tahoe
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
