how much space do I have
You model the driver in the airspace you've got and size the port for your power. Length is to tune and it changes volume as well so it's something you wanna watch... simple
I seen alpine rec 12 sq in port but that's for rectangle port.. About what would i need for aero port?
I can do 22 inches but the ports have to go under box box bend and fire under the seat
Unless you've got some vision, I'd suggest a slot as bends will allow you to use a longer port... You said 3.2ft3 or something originally so you've got the space... I'd use it. Unless it's sitting in my driveway I sure cant envision the thing... you're building it... lol
I can help you with port area for a slot, but I modeled it 2-3 times already for different drivers and ports... maybe try learning Winisd?
That Torres screenshot you posted is NO help as the dimensions you used are not visible
Maybe hand draw the thing as someone else suggested... IDK
Yea I should... And I will. Just one question, will it kill my output if I fire the ports under the seat?? Learning. The programming won't tell me why I need more port volume.. But I've learned a lot already I appreciate your time.
As long as they're unobstructed you'll be fine.
Alright thanks.. I may go slotted I just wanted to go there best route to eliminate port noise bc it's in a cab of a truck. If I go that way I think I cab figure it out . I've been playing with the software. Thanks man. I'll post when I get it built.
jdeaton011989
Mississippi
jdeaton011989
