well the vas of a 12w7 is around 2,6 ^ ft.. The only thing i could see a near 5^ft sealed box for is HTno, i meant double.
and it depends.
you want to go big without sacrificing output (by your own accord) *what it says up there*
if you are going SPL only then a smaller box is in order.
so basically you amd iamamp3pimp are 180 degrees different... like i said from the beginning i just wanna build i nice sealed box for it and a pressure enclosure to just do some testing, since i really dont think my 2.2^ ft enclosure w 25 ^ inches of port tuned low is the top # ill see on the TL.. which at this point is 143.6 @ 46 hzDoubling the Vas is the point where you're going too big and the sub is going to start sounding like it was on an infinite baffle. At double the Vas, you are putting your Qtc close to the Qts of the driver. Theoretically, when the Qtc is very close to the Qts of the driver, it's performing free-air.
thats what i was saying, as your ? was how big is too big.I think he was saying that the max you should go sealed would be double the Vas and I think that is going a little too far.
aaaahhhhh k... So is that just another "daily" enclosure setup used by many? id love to see what this expensive pos can do in a sealed enclosure thats meant to be tuned low ( or however you do or say it ) sealedit will bring out the low end a little more, compared to that recommended enclosure.
