32 W x 25 D x 17.5 H...
Nobody responds to my questions..//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif :( //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
6.63 cubes gross. Will be close. I dont have my calculator around me right now. Ho much port area you looking at?
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's another problem..according to the "subwoofer-tools" website, it says around 80, but I've been told around 105+ square inches of port is nastyy
not even close.
you probably can't even get 5 with 80in^2 let alone 100in^2
EDIT: even with 80in^2 you're down to well under 4 ft^3 after the displacement of the 6ft+ long port you'd need.
If your tight on volume, try aeros. At least then you wont need as much port area...
I was thinking about doing aero ports but wasn't sure..
not even close.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=32&Eh=18&Dia=9&Xmax=27&Vd=.15&NumW=1&Vb=6&Fb=28&Qts=&Vas=&Fs=&CE=0
Subwoofer tools ftl?
EDIT: I'm not a box building guru either..
yeah, that looks right to me.
i was sticking with the original dimensions and with that port area, it's about 4ft^3, once you start upping the port area the net volume goes down quick.
if you can fit that box, i think it'd work well.
if you play with the site you can see that trying to make the net volume smaller won't make the box that much smaller, because the port will have to get longer to achieve the same tuning.
Sonnick
> You
Sonnick
Long Island
xluben
michigan born
    May 14, 2026
michigan born
    May 14, 2026
