How many watts
Yes it is...plenty of people on here run stock alternators. I'm running 1800 off an 80 amp, + a kinetik hc600 in the trunk and I drop to 12.5.
Mathematically, you wouldn't be able to run very many...but you really just need to try it, everyone's results vary.
How can you start off saying yes its enough, and finish by saying everyone's results vary?
Listening habits + car usage factor into this, and we have no way of knowing either. As for how much your car uses, it depends if you have your headlights on, the heater, AC, etc. How long these things are on, and how often, also factor in. There is no easy answer to this question.
So without the system on and AC/heat off, would it be using closer to the full 95 amps to run the car or not? Like, if i am only using 20 amps out of the 95 without the system on, then that tells me there is quiet a bit of power to feed the system. If i am using 50-80 like one of the posters above said, then i barely have any power left to power the system. I would be much happier to know that i am barely getting any power to my system without a HO alt because i am buying one soon hoping it will make a HUGE difference.
Ya I hear the base line is around 1500 watts on normal stock alt. I would say about 100 amp alt would be what it's based off. If you do the big 3 I would say it's safe to run a good 1400 watts off of stock electrical. I'll find out when I get my new sub
it can't be on mine because just running 1,000 to a sub i go down around 11 volts on the amp. That is terrible. And i cannot run the air in my car when i have the subs playing loud at all.
Alpine4life89
Alpine4life89
missouri
audiolife
