How many watts would this put to each sub?
AKMX824
How many watts would a kicker zx 450.2 amp SPECS BELOW.
Put to two Shallow Mount Rockford fosgate 12'' Dual Slims SPECS BELOW:
There in a under rear seat box.
SUB SPECS:
12"
Impedance 4-Ohm x 2
Power Handling 400 Watts RMS
800 Watts Max
Voice Coil Diameter 2.5" 4-Layer
(6.35 cm)
Motor Size 52 oz.
Speaker Connector Dual 10 AWG compression
SPL (1W/1M) 86 dB
Mounting Depth 3.625 in.
(9.21 cm)
AMP Specs:
Kicker ZX 450.2
150 watts RMS x 2 at 4 ohms
225 watts RMS x 2 at 2 ohms
450 watts RMS x 1 in bridged mode
remote level control included with with 20' cable
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
3-way protection circuitry
speaker- and preamp-level inputs
bass boost (0-18 dB) centered at 40 Hz
variable high-/low-pass crossover (50-200 Hz, 12 dB per octave)
frequency response: 20Hz - 20kHz
preamp outputs
two 30-amp fuses
AKMX824
AKMX824
Palmer, AK
Calikid
