How many terminal cups
Then how would I wire the subs inside the box??? From looking at the diagram in the sticky I cant figure out how they could be wired.
You would wire each sub to 2 ohms, by wiring the + and - of each coil together. Then wire the + and - of the exterior terminals together, and a + off one to the amp, and a - off the other.
The amp is a Power Acoustik A2100DB. It has two sets of hookups and i dont think it can be bridged. I did some looking around and cant find anywhere that says it can be bridged.
That would give you 8 ohms at each sub. You want to wire the + to the + of each coil and then all of them together.
That's the D series on Power Accoustik. While it may look like there are two seperate terminals, it's really just one (they're internally bridged). The amp is 1 ohm stable.
I love my terminals...saves tons of time when wiring subs. I can change The VC wiring with ease.
Pics
So if i just one one set of wires out of one side it would get the same power as it would if it was bridged??
I said wire the + and - of each coil together, meaning both +'s would be wired together and both -'s. Rereading what I wrote it isn't so clear...
Just had to clear that up, so you guys don't think I'm like...a jack *** or something //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
And 12 guage wiring is fine for your power.
So if I just run one set of wires out of the amp it will get the same power as if it was bridged???
SEVEN_ELEVEN
SEVEN_ELEVEN
Leavenworth, KS
SEVEN_ELEVEN
