How many layers
i would go ahead and put one layer on and then listen to it and see how it sounds. if its not quite good enough, i'd go ahead and put another layer on, but i probably wouldnt put more than 3 layers on...
more then two layers is a waste of cash, unless you plan on doing serious competion db drag, but if you want to waste the money peel up the first layer and get it professionally sprayed in then ad a peel and stick layer , that what i had to do to my car to kill the road noise and keep the sound in
you can use rhino lyning like the spray in truck bed stuff, it works good and cost probley 100 bucks, but youll have to completley gut the area to be sprayed, dynomat and stinger have the spray too, but its basically the same stuff , but they charge more for there brands
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
Everclear
Everclear
Iowa
jgallo772
