How many fuses for secondary battery
murph
Low for Life
So I will have a fuse on the positive wire from the first batt do I need one before I connect the positive wire to my second batt? Also should I put one from my positive from the second battery to the amp? Sorry for the questions just want to make sure it is all safe.
If you don't fuse both batteries there's no point in fusing one. Say your positive run shorts out it will blow the one fuse and then your left with the non-fused battery to cause a fire.
in short I need 3 fuses thanks everyone for the help
murph
Low for Life
murph
Richmond,VA
Chrispy
