How many feet of wire?
wokeupquick
I ordered 20 feet of KnuKonceptz power wire for my install and was wondering how much wire I should have leftover to do some Big 3 work?
Wondering because I'm going to be doing the Big 3 work first to solve some other problems... Don't want to be short wire for the subwoofer install.
It's a Mazda 6 sedan. I only plan on doing the ground wire right now, since the stock ground is garbage. Do you think 19 feet will suffice for the install? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Its ALL vehicle dependant.Where the battery is,What side you run the power wire down,Where the alt is located.Just to many varibles to give an exact answer.I would say 17ft should do you and leave you with about 3ft for extra.
Ok, I was wanted to make sure I could work with 18-19. Where do you guys suggest I buy ring terminals?
Also, I'm looking to replace the bolts that keep my battery terminals connected, were should I get these bolts/nuts?
All at a hardware store?
wokeupquick
wokeupquick
Rsvl, MN
wokeupquick
