how many ( amps/rms ) can i run throw 1/0 wire ?
  • 5
ok when you say 300 +/- does that mean if i add what each amp takes like my ppi amp takes a 160 amp fuse, and i just add them up ?
the fuse rating is just incase something goes wrong on an amp, normally an amp will only pull about half of its fuse rating. I meant by +/- give or take a couple of amps.
just to keep things simple you will be fine, like others have said
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
big scott
blazin low, and loud
big scott
edgewood, md
Slobalt
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
