how many aeroports???
SPL140.2
Team DefJ
This is my max dimensions on my new enclosure 32WX15HX20D all using .75 MDF with a double baffle. How many 4" aeroports do you guys recommend??
Im building 3 enclosures for testing,
SUB/SUB/PORT, SUB/PORT/SUB, CRX STYLE all with the dimensions givin above. The equipment used for these enclosures is in my sig below. Thanks guys for the help.
Two per sub //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
Orient the ports 90degrees opposite of the subs... then mess around with firing the same box different directions...subs and port.
nG
nG
Does that rule of thumb matter if they are 4" or 6". I know the tuning will but what about diameter?
here are some pics of the enclosure so far, some more things todo to the inside //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I want to put the aeroports on the drivers side for testing than ill flip it over and test the enclosure with the ports on the passanger side than....test,test..//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif This is ENCLOSURE #1, ENCLOSURE #2 next week with ports in the middle of woofers, ENCLOSURE #3 CRX style when I have some free time and more MDF.
Egg
dimensions are listed on the first post //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SPL140.2
Team DefJ
SPL140.2
NY
SPL140.2
