how long should my rcas be?
Duocin
i was told i would need 3 sets of rca's to wire a cadence 150x2 amp to my pg components and a cadence 1000x1 amp to 2 type r's in the trunk . i got 3 sets of knukonceptz that are 13ft long but now i dont think that will be lonng enough.
should i order 3 sets that are each 20ft long? if so i only need the 2 channel rca cables right? also do i need to get a y-adapter ?
Long enough to reach the amp...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Something for you to measure...you only need two sets of the two-channel ones, no Y-adapters needed.
It also depends highly on where you're routing your RCA's. If you go from the HU right down the center to the trunk it might only take 8 or 10', but if you go underneath the dash and along the side it might take ~15' or more.
Duocin
Duocin
bay area, ca
SethPhillips
