How long have you been using your amplifier make\model\time
System #1
Avionixx AXA 440.4 @2 ohm front/4ohm rear - 6 yrs
HiFonics Brutus BXI 1205D @ 1 ohm - 6 yrs
2 Powerbass 2XL 15D's- 6yrs
System #2
Avionixx AXA 440.4 A 2 ohms/all 4 ch. - 5 yrs
AQ 2200D @ 1 ohm - 5 yrs
2 Powerbass 3XL 15D's - 5 yrs.
trying out DB drive A31000D for 2 wks in sys #1..going back to the ol trusty Brute next weekend.
System #1Avionixx AXA 440.4 @2 ohm front/4ohm rear - 6 yrs
System #2
How are those powerbasses?
Coustic Amp 280 been in use off and on since '94. Pulled out last weekend from its fourth car. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Can't seem to kill the thing.
I keep coming back to RF Power Series after trying so many other brands. The only difference is now instead of using the T400-4 I switched to a T600-4 and it is a night and day difference in quality of sound, probably because the T600-4 is more power. I own a T1000-1BDCP and T1500-1BDCP and will use the 1500 for my 2 SEs. However, I am going to a 1 sub setup which will be 1 15 ported @ 33-35hz and for that I will use the T1000-1BDCP.
2 lanzar vibes 1200d/ on 2 pioneer premier 10/ wife's daily ride/ 9 yrs and some months. fosgate p300s about 7 yrs// crunch groundpounder gp4150 1 year, and this amp sounds amazing crunch groundpounder gp3000dpro/ 1 year/ also an great amp
Still rocking the same, but soon to retire the vibes and pioneers, they've earned it.
jbl Px300.4 for 7 years. It's been bolted to the back of my diesel's cab and has been vibrated to almost death. It started acting up and found out it had between 75 and 100 cracked solder joints that had to be resoldered. Because of a ground issue it is mounted to a piece of plywood. As soon as I get my Linear Power amp I'm going to get it repaired and sell it.
What is your voltage doing when you hard accelerate or brake? The civic have a complex alt control that shuts the alt down to save fuel. Its...
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Macklessdaddy
Macklessdaddy
San Diego
quackhead
    Jun 1, 2024
    May 31, 2024
