how in h e l l Do u wire a jlw7
The 12w7 is an SVC sub, correct? Which means a single 3ohm coil, not dual coils.
But, regardless. Nothing "special" has to be done. You wire it just like every other woofer.
okok i see it on the website....but seeing that i only have one i can only have the option at wiring it at 3 ohm....is my amp 3 ohm stable??? how can u wire one to 1.5ohmss???
Amp is 3-ohm stable. For 1.5ohm get 2 12w7s //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif or 1 13w7 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if ur amp is stable at 1ohm, its gonna be stable at 3 unless some freak of nature occurs. ignore my first post cuz i didnt know 12w7's were SVC so u cant wire a single SVC3 at 1.5, only 3.
truu i think ima either go wit 2 10w7....but i would only be able to afford one right now then get another one in like AMNY montthsssss months later....or get two 8w7's now .. i'll be able to run both at 1.5 ohhm ...both getting ideall power...and wit those i 'll have room to port them....but with the 10's i wont be able to port them...wont have enough room..i would have to leave sealed
wat would you guys recmonnd????
do u have to get w7's? i would recommend dual 13w6v2's //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif otherwise, save ur money till u can afford exactly what u want.
sell the kicker and pick up a used PG T1200.1, ive seen 2 or 3 forsale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
should give u about 1000watts @3ohm
Actually, the tantrum 1200.1 should give you 1400wrms at 3 ohms //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
spicmonster
spicmonster
New York CITY
spicmonster
michigan born
    May 14, 2026
michigan born
    May 14, 2026
