How important is proper ground????
Black Truck 10
My real question is, how important is it to have all my grounds go to 1 spot? Reason I am asking this is because I will have 1 battery in my toolbox (in bed of truck) 1 battery up front under the hood. I will then have 3 amps to ground inside the cab of my truck on the back wall. I thought about grounding my amps and my negative battery cable from my battery in the tool box to the same spot, but do I really need to run my battery negative from the front battery all the way to the rear? Or will I be ok with just grounding that to the front chassis, and everything else to the rear of the chassis?
While im at it, just to make sure I can use a distribution block regardless or + or -. What I mean is can I buy 2 of the same distribution blocks, and use 1 as my ground distribution, and 1 as my power distribution. im pretty sure I can but I just want to make sure.
Having the multiple grounds is perfectly fine.
your front battery is already grounded. If you add another ground to it, it will be 1/3 of the big 3. You dont have to ground to the same spot and personaly, I would ground the second batt to the front and run all your grounds to the negitive on the second batt.
Ok so ground off the front battery, then take my 1/0 from my 2nd battery negative run in inside the cab to the distroblock and collect the ground 4 gage wires. Then run another 1/0 from the 2nd battery negative to the chassis of the car.
Do I have this correct? and I shouldnt expect any noise or interference?
That's how I would do it.
x2. I'd do this. Run 1/0 neg from front bat to rear bat and then run 1/0 from rear bat to distro block for 3 amps ground. And never expect not to have noise. Then you definitely will. No amount of 'proper' grounding can stop noise. It can be a beotch.
Oh ok so Im needing 2 runs of 1/0 from my front battery to my rear battery 1 "+" and 1 for "-". That makes sense.
Ill probably look for a battery terminal then since that would be 2 1/0 from my negative on my main battery and 2 from my extra battery. Thank yall then, this looks like itll work
You can run dual runs of 1/0, and add another ground in the rear near your amps. You can never have enough grounds.
haha I hope he means fuse, because if Im supposed to ground a positive that could lead to some serious confusion. I planned on doing 250 amp anl fuses for the 1/0 wires. I wont have to add a fuse aft my distribution block inside the cab would I? ill be going from 1-1/0 to 3-4 gauge wires, each run would be like 2 feet.
I've never fused from 1/0 to 4g when the run is so short. If you end up going over 2 feet definitely do. Don't forget to fuse the positive run from the rear bat within 18" to the distro either.
I would also recommend using a firewall bushing for each wire you cut through metal for to help protect the wire and keep moisture out.
Ya I was going to use a total of 2 anl fuses. 1 about 10 inches aft my 1st battery, and the other at the same spot on aft my second battery. (250 ANL fuse correct or should I go 300? I know the wire itself goes up to 350 amp I believe ( I get a bit confused here)
Black Truck 10
Black Truck 10
Houston, Tx
jrwalte
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
