if this is the question, be sure it's set on ~200v AC and put the leads on the speaker outputs of the amp. be sure no speakers are hooked up when you play the test tone.are you asking where you put the leads?
check post #2 for referenceSo you take your measurements at the speaker outputs and not at the RCAs coming from the HU to the amp? Do you put the DMM + lead on the speaker out+ and neg DMM lead on the same channel's speaker - lead? Should these measurements be taken with HU's volume control turned up to max volume? And using what source material?
never heard of this. how would you set the gain to 5v?You need to set your gains to the input voltage of your head units RCA outputs. If you have a 5v preout, then you can just set your gain to 5v. If you want to be more accurate, Set your DMM to read 12vdc then check the output voltage of your RCA's by placing the positive lead on the center conductor of the RCA, and the negative lead on the outside conductor of the RCA.
