how do you figure subwoofer QS?
The Soundstream Tarantula T4-15
1000
VOICE COIL DIAMETERS (INCHES) : 4.0
MAGNET WEIGHT (Oz.) : 250
FREQ. RESPONSE (Hz) : 20 - 1k
Fs (Hz) : 34
Qes: 0.449
Qms: 3.722
Qts: 0.401
Vas (Ft3) : 2.08/58.77 liters
Xmax (INCHES) 0.551
SPL (dB) : 91
HOLE SIZE (INCHES) : 14.25
WOOFER DEPTH (INCHES) : 8.25
RECOMMENDED ENCLOSURE (Ft3) : Ported 4.25
RECOMMENDED ENCLOSURE TYPE : Vented
AEROPORT DEMENSIONS (INCHES): 3 x 3 (2)
If the EBP=75.72 how can it be designed for ported enclosures only? EBP between 50 and 90 should function well in any enclosure.
Well, looking at it from a "spec" point of view: EBP puts it smack dab in the middle, the Qts sets it right on the boarder line of sealed/ported, but the Fs is a little high and it has relatively poor excursion capabilities. So, all in all, it would probably "work" sealed, but better results would be had with a ported enclosure.
fholla
fholla
St. Louis, MO
squeak9798
