how do voice coils work???
Long story short, they are a copper tube (for lack of a better term) inside a magnetic field, which is what moves the cone up and down. It is an electro-magnet.
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
872
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
484
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
crhye250r
    May 16, 2024
    May 16, 2024
