How do I wire my system? Dual Alpine Type S and PDX
Nightstrife408
18
USA
Hi guys I have 2 12'' Alpine Type S rated 4 ohms dvc (SWS-1243D) in a sealed box and an Alpine PDX 1.600.
What should I buy and what should I do to be able to wire the entire system from battery to stereo to amp to subwoofer? I'm sure I can figure out the installation as there are many youtube videos but I'm just very unsure about the needed supplies and materials.
Some people have recommended a ''KnuKonceptz KCA Complete 4 Gauge Amp Installation Kit'' from amazon but I'm not sure if thats all I need.
Also any recommendations about gauge of wire would be awesome. I've been getting a lot of mixed answers and unclear ones from google so I need some help. Thanks guys!
Get a 4 Gauge amp kit from KnuKonceptz or AudioTechnix. It'll include everything you need EXCEPT for speaker wire to connect the amp to the subwoofers. 10ga speaker wire is for sale really cheap on the Amp Installation Kits, HDMI Cables closeouts. Wire the subwoofers to 4 ohms.
I'd make a run of 0 gauge, "I know it's not needed for this install"
Yet if you ever want to run more power it will be there.
Run it to a distribution block and 4 gauge to amp(s).
Could save you money in the long run...
How much speaker wire do you think I would need in terms of feet? It would be used to connect subs to box (inside box) and box to amp right?
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
470
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
881
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
862
Nightstrife408
Nightstrife408
USA
Nightstrife408
    May 12, 2024
Brendon Jenness
    May 11, 2024
