how do I calculate tuning voltage on 3 woofers?
So it doesn't matter whether there are 2 or 3 woofers the formula remains the same ? I use the rms of the woofer because I don't to blow it if the amp is too powerful.
So that means givingThese 400watt rms woofers 800watts. They are 400rms though, wont i over power?
you are not gonna blow sh*t stop worrying about it. Your amp's not gonna produce anywhere near that much power. Music is dynamic just because your amp says it can do 1000 rms doesn't mean you'll get close to 1000 rms in actual performance set after accounting in impedance rise.
Yeah but The apodera aré 400rms
i would encourage you to read up on impedance/box rise and look at clamp tests. Lets say You set your amp to do 1000 rms with the multi-meter, however after voltage drops, impedance rise and an actual load on it, you wont get anywhere near 1000 rms. That the exact reason why people have been able to push 2000 watts rms to two 600 rms subs with ease. Its not because its a strong and good sub, its because of every else going on in the system.
with this said, should I tune to 800 watt peak? instead of 400 rms ? This way my gain is set to max and I can control with bass knob?
ok, time to change the tuning voltage because this ******* just pierced through the rubber foam around teh cone with his drill. Who fixes this and how much?> //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
mrpep
mrpep
chicago
ThatChevyGuy
