how do I calculate tuning voltage on 3 woofers?
I am trying to tune teh amp though , what calculation should I use?
400 watt rms x 2.67 ohms = 1068 volts square root = 32 volts.
Does that sound right?
You have to calculate the rms of the amp x 2.67, not the subs. At that ohm load, you are closer to 800rms. on the amp.
Negative ghostrider. You use the wattage you want the amp to put out. if you use rms of the amp that will tell you what voltage of that amout of watts. OP you are correct find the rms you want coming out of the amp and use that number times 2.67.
The amp is 1000 rms@2 ohm. At 2.67 it's closer to 800rms. So 800x2.67 is what you calculate.
So it doesn't matter whether there are 2 or 3 woofers the formula remains the same ? I use the rms of the woofer because I don't to blow it if the amp is too powerful.
Yes, correct if you want to output 800 watts. However, he does not want to output 800 watts rms he wants to output 400 or whatever op wrote. You tune for what you want the output to be hence ohms law. Use the equation to find the missing piece.
You have 3 400rms subs. With that amp load you are not running too much power at all.
Correct op. Just use your final impedence multiplied by the rms you WANT to output and take the square root of that to find vac
mrpep
mrpep
chicago
ThatChevyGuy
