How do I attach my wire to this?
bitsnack
canada
Hello,
I've been looking for an answer all day, but found nothing!
It's nothing fancy, I just bought some new speakers to replace the stock
ones but I am unable to connect them safely. Here is a link to the connectors:
Why cant I post a link? I really need help.
Thank you.
Your post count is too low. Once you build it up, you'll be able to post links. You have two options to connect those speakers. Either use quick disconnects (recommended) or solder directly to the terminal.
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
205
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
708
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
937
bitsnack
bitsnack
canada
neo_styles
    May 24, 2024
