How can i wire this amp for one ohm
if each voice coil is 2 ohm just wire it in parallel and you will get a one ohm load. There are 2 pr of outputs for connection purposes they are internally bridged.
The two sets of speaker inputs is just to make it easier to wire multiple subs to the amp instead of running wire from one sub to another. Wire the sub in parallel inside the box then connect the wire from the back of the box to the corresponding one positive and negative terminal. You wont need to use the other terminal.
....You will wire the VC in series for a final impedance of 2 ohms. The Memphis is a 1 ohm stable amp. By using a D1 sub, you can only use part of the amplifiers total power abilities. Look at it this way though...at least it will be more efficient and less of a strain on your electrical.
southport2014
southport2014
Indianapolis, IN
quackhead
