How are you guys grounding your head unit?
How is your head unit grounded?
  • Ground via the factory harness.
    Votes: 11 36.7%
  • Grounding point behind the dash.
    Votes: 16 53.3%
  • Grounded to the battery terminal.
    Votes: 3 10.0%
  • Total voters
    30
yeah you need at least 4gauge ground wire for your headunit...dont want it to be a weak point in your system....
hahahah, i cant believe more than one person took shava seriously....as long as its a good ground wire (not corroded) you should be fine there...sounds like its a problem with smth else...maybe rcas or your speakers...
You can make the ground wire larger than the power wire, but that makes no sense. I have a few things to ground, so I ran 8g to a seat bolt under the carpet. My factory harness has a tiny wire.
I ground mine directly to the neg batt terminal with ordinary 12ga automotive wire. But because I'm anal, I also ground the HU chassis to the factory ground (even though I know it's already grounded internally). //content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gif
vpkb1998
vpkb1998
Palm Springs, CA
wesl56
