hooking up a switch to turn off amps
okay i hooked up a switch to turn off my amps. and i ran it to the 2 sub amps and not the comp. amp remote wire. but when i flip the switch it turns off all of my amps. how can i fix this so it only turns off the sub amp and not the comp amp thanxs alot.
i believe if you run the wire to your comp amp, then a wire from the comp amp and a toggle switch between the 2 amps. if that doesn't work, run a wire from the red acc. wire in the deck to the sub amp with a toggle switch in between and a wire from the remote lead to the comp amp.
Johnston_2007
Johnston_2007
Bonne Terre, MO
Johnston_2007
