Hook up 2ohm sub bridged. Safe or not?
i will conceed that it may be possible to set the gain low enough to ensure the amp doesn't go into protect, even bridged at 2 ohms. but we didn't tell him what the gain should be set at to achieve this.
determining the voltage required out of the amp to safely run at 2 ohms mono requires solving simultaneous equations of ohms law (7th grade math). basically, you want the current out of the amp to be the same at 2 ohms bridged as it is at 4 ohms bridged. since the relationship is non-linear, the calculation is as follows:
P=I^2R
500W=I^2(4)
I = SQRT(500/4)=11.4A
V=IR
V=(11.4)(2) = 22.8 VAC
which gives
P=V^2/R
P=(22.8)^2 / (2)
P=260W
that KW would make a most excellent throw line weight down on the Ohio River......if u like to fish, that is....lol. Seriously, send that JL sub back and get what you paid for. It is not your fault they shipped you the wrong item. You designed a system and ordered the correct product, you should not have to suffer because of a retailer mistake..period.
Michael555
Michael555
Evansville,IN
quackhead
