hoo do u wire to get a 2 ohm load??
go to rockfordfosgate.com they have a good program for diagrams on wiring subs. are those dual 2ohm subs?? cause if they are just do a series/parallel wire setup. each DVC in series 4ohm per sub then parallel to get you a 2ohm mono load.
adam
Originally posted by Hurst421 I have a 2ohm stable amp and two 2ohm subs. HOW do i wire them to get a 2 ohm load.
A diagram or a sitte please???
Can't get there from here my man. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You can have two 2ohm loads. But for a mono load you will only be able to achieve 1ohm or 4ohm. Depending on the amp though, might be able to run them at 1ohm. What kind of amp ya got ? And what kind of enclosure? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hurst421
Hurst421
Hershey,PA
MikeofTulsa
