and do you know what rms testing is? means you can run a sine wave with 1000w TRUE power to the coils for as long as you want. If you knew anything about amplifiers you'd know your 500w amp probably delivers 200w to your sub most of the time at most frequencies.
Max usually means for music also. Do some research on thermal powerhandling, and what makes for good powerhandling.
Brahma, rated for 1600wrms has much less coil than this sub, that is part of the XBL^2 technology, use the least amount of coil as possible.
XXX rated at 1600wrms as well but people say 1000's and 1000's of watts powerhandling, yet also has less coil.
H2 rated at 2000wrms ALSO has less coil.
magnum D2 rated at 1000wrms at well, recommended amps by the owner is 1500w-2000w amps, this sub has similar coils to the PBX.
Read trixters review, his PBX handled MUCH more abuse than his Brahma.
