Hole in speaker cone
  • 2
chucku
Help. I just removed my door panels to deaden my doors and found a small hole in my 6.5 mbq comps. It looks like my friend slipped with a screwdriver when he installed them. I searched on repair but found nothing. What would repair the hole and not affect sound? TIA, Chuck
The hole is about the size of a phillips screwdriver head. I thought I heard some distortion from that speaker, and upon further inspection, since the hole is near the edge, some of the cone was separated from the surround. I went ahead and superglued the part back together and cut a small piece of clear package plastic and glued it over the hole. I just put the door back together and tested it out, sounds good.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
153
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
322
439
chucku
chucku
new hampshire
chucku
SPLBassJunkie
    May 21, 2024
    May 20, 2024
