I'm a bit confuse about this alternator calculation although I know you need power to get power
Monday i'm going to have my system install
do I really need an HO alternator im a perfectionist I like to do things perfect than coming to redo it
rockford power T1500-1bdcp
on bass with two old school MTX 10"
(amp fuse rating)
Operating Voltage
9 - 16 VDC
Recommended Fuse
(not included)
200 A
Average Current Draw (13.8V Music)
100 A
Orion XTR 1700.4
(six) b&c 6'' neo
(pair) db drive P5TW 5D tweeter
(pair) nb1's
(amp fuse rating)
- Fuses: 150A recommended
XS Power D3100
in the trunk for secondary battery
battery in the engine
My stock alternator is
110A
(amp fuse rating)
Operating Voltage
9 - 16 VDC
Recommended Fuse
(not included)
200 A
100 A
Orion XTR 1700.4
(six) b&c 6'' neo
(pair) nb1's
(amp fuse rating)
XS Power D3100
- Deep Cycle 12-Volt AGM Battery
- Group 31
- Max Amps: 5,000
- Cold Cranking Amps: 1,376
- Reserve Capacity: 273 minutes
- M6 Terminal Hardware Incl.
- Charging Temp: 5°F: 120°F (-15°C to 50°C)
- 78 lbs.
MF 85D26L
PLATES : 15945
HOT CRANKING AMPS (HCA)
630COLD CRANKING AMPS (CCA)
72CAPACITY (Ah)
110A
