Ho Alternator
Matthew17
CarAudio.com Newbie
I'm a bit confuse about this alternator calculation although I know you need power to get power
Monday i'm going to have my system install
do I really need an HO alternator im a perfectionist I like to do things perfect than coming to redo it
rockford power T1500-1bdcp
on bass with two old school MTX 10"
(amp fuse rating)
Operating Voltage
9 - 16 VDC
Recommended Fuse
(not included)
200 A
Average Current Draw (13.8V Music)
100 A
Orion XTR 1700.4
(six) b&c 6'' neo
(pair) db drive P5TW 5D tweeter
(pair) nb1's
(amp fuse rating)
- Fuses: 150A recommended
XS Power D3100
in the trunk for secondary battery
  • Deep Cycle 12-Volt AGM Battery
  • Group 31
  • Max Amps: 5,000
  • Cold Cranking Amps: 1,376
  • Reserve Capacity: 273 minutes
  • M6 Terminal Hardware Incl.
  • Charging Temp: 5°F: 120°F (-15°C to 50°C)
  • 78 lbs.
battery in the engine
MF 85D26L​
PLATES : 15
945​
HOT CRANKING AMPS (HCA)​
630
COLD CRANKING AMPS (CCA)​
72
CAPACITY (Ah)​
My stock alternator is
110A
Honestly you should be good with just what you got. The draw from your sub amp won't be constant with music allowing the alt to charge between big draws.
I'd honestly wait and see if it's necessary before dropping ho money 😂
You don't need one. Get an isolator for your batteries though, preferably a smart one.
If you do choose to get a HO alternator don't go pretty or popular. I have two LActrical HO alternators, as ugly as factory ones, one in a suburban one in a 300. I bring all my alternators to an old electrical shop that's been around for 63 years. These LActrical alts actually push the rated amperage and they last. 7 years for the suburban and 3 for the 300 both still abused daily. I bring them in annually and not a single repair needed and same amperage output every year, for half the price tag of the ones marketed to car audio folks. I know people who paid 450, 600, 750 for Mechman, JS, GP, XDP, and one guy who paid 1500 for two. My shop repairs as many of those as factory ones being many get electrical services there specific to car audio, towing and camping. I paid 533 for my two HOs and 15 bucks annually to get them both properly tested.
If 275 ain't a big hit to the wallet there you go, but just doing a wire(big 3 big 4) upgrade can do wonders. And honestly, you took the right route in going dual battery before an HO alt.
Yea I will install first an them I will know what I need my mind tells me NO but the OCD says yes :(
thanks for the feedback I'll monitor it an know what im I doing after the install
Matthew17
CarAudio.com Newbie
Matthew17
Unknown
Matthew17
