k, i'll try a slot, havent done one in years so why not. I guess i've never built a box so far off cause I can't believe it would have that much of an effect. Hopefully that will do the trick. we'll found out in the next couple of days though.that sub should need about 24-26" of port area, a 4" pvc port dose not even come close to that. imo, 1.5 cubes with at least 26" of slot port should do the trick.
here is a pic of a box that was built for me (my specs), its 1.5cuft, tuned to 37hz with 28" of port. its for a dd 3510 and i fed it a solid 2k+rms(clean) and there was never any port noise and had **** tons of output.
cool, thanks a lotVic is right. The hdc needs 16" of port opening area per net cubic foot. You have 12" of port opening area for 1.5 cubes which is half of what you need. Vic's box is right on.
schedule 40 pvc, .25 inch thick wallyou dont need a swimmingpool of portarea to get loud, if it so you guys must have some strange air in your country, many over in europe plays 140-150db with a single 4" aero, but the flared port is a big +++! but your pipe looked thick, is it true 4"?
this is how the patented aeroport looks like, http://www.blekingebilradio.se/ProductPopup.aspx?filename=frov-aero1_7903.jpg
only the pipe that you call aeroport we call only pipe, and in most case like 90% of the people plays louder with aeroports than slotport, you must modify the slot to have it good as the aeros, or have this swimmingpool area for not have the portnoise
people seem to say that as a general rule but thats assuming the aero is flared, which your port is not....i thought you only needed half the port area with aeros than slot
give or take some.i thought you only needed half the port area with aeros than slot
