hissing from tweeters please help $20 whoever helps solve problem
rxzoco
hello guys
i am having a issue i have a 2004 sl55
i did a full sound system on it
and the tweeters are having a hissing noise from tweeters when car is idle
there is no hissing noise when car is just ignition on
i have 3 way focal krx3 for the fronts
powered by phoenix gold ti 1000\4
very thick monster cable rca
subwoofer 13" w5 shallow
powerd by a jl audio 500\1
with the new pioneer double din
with a monster cap
i have tried gounding it on battery to see what happens makes a worse hissing noise
now im using the ground near the pse pump which is a very firm ground
i have check rca speaker wire everything is monster cable
any idea? i even put a isolator ground loop still hissing
when i rev it no engine noise just hiss
please someone help should i ground it better i even try grounding the rca makes it worse
please help
i already try removing the rca and hissing noise still coming from tweeters im thinking
maybe bad cap? or bad deck? please help
ill personally paypal you $20 if your idea works please help thx
Does your passive crossover have a way to turn the tweeter down some?..some passives have a 0 & -3 db setting.
Or look at your equalizer And turn the 10k band down some...or What Ever is the highest band.
rxzoco
rxzoco
san francisco
pickup1
michigan born
    May 14, 2026
michigan born
    May 14, 2026
