hissing from tweeters please help $20 whoever helps solve problem
rxzoco
hello guys
i am having a issue i have a 2004 sl55
i did a full sound system on it
and the tweeters are having a hissing noise from tweeters when car is idle
there is no hissing noise when car is just ignition on
i have 3 way focal krx3 for the fronts
powered by phoenix gold ti 1000\4
very thick monster cable rca
subwoofer 13" w5 shallow
powerd by a jl audio 500\1
with the new pioneer double din
with a monster cap
i have tried gounding it on battery to see what happens makes a worse hissing noise
now im using the ground near the pse pump which is a very firm ground
i have check rca speaker wire everything is monster cable
any idea? i even put a isolator ground loop still hissing
when i rev it no engine noise just hiss
please someone help should i ground it better i even try grounding the rca makes it worse
please help
i already try removing the rca and hissing noise still coming from tweeters im thinking
maybe bad cap? or bad deck? please help
ill personally paypal you $20 if your idea works please help thx
Does your passive crossover have a way to turn the tweeter down some?..some passives have a 0 & -3 db setting.
Or look at your equalizer And turn the 10k band down some...or What Ever is the highest band.
rxzoco
rxzoco
san francisco
pickup1
