High Quality Shallow Coaxials/ Intergrated Tweeter
Yeah, I can't do it with the cal27.
Wouldn't the excursion of the mid hit the strapping.
That would work if I could pull it off as the door panel is concave, which would facilitate such an install.
That straping is so soft that you can contour it easily around the surround leaving enough clearance.
You could use a Cal25 or cal25titan as they are more compact....cal25titan would actually be a good choice being it would be trapped behind a door panel grill and should get you the extension you need.
I will consider pairing the x-line...maybe
You will prolly get a PM concerning the matter in a couple minutes or so.
Flipx99
Violator of Terms
Flipx99
Building 100
AK SloPok
