High Output Alt
subzero
which batery would you get for a 10kw system?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270692480769&hlp=false&rvr_id=208021306044&crlp=1_263602_304652&UA=WXI7&GUID=82f1840d12d0a06437e5cfe5fff15c38&itemid=270692480769&ff4=263602_304652
http://www.stingerelectronics.com/productDetails.aspx?ProductId=139&CategoryID=4
http://www.batcap.net/Products/BatCapProductLine/tabid/58/Default.aspx
I also need to know about battery stuff. I am going to be buying extra batteries to put in my trunk.
I am going to spend about $1500 on power upgrades and $1700 on subs and amps.
I need to know if it is wiser or better to: have one huge alternator of two medium sized alternators or two stock alternators for easy replacement?
I need to know if I need a seprate regulator to kepp the higher current away from the primary electrical system that controls the car and keep the secondary system for the audioz.
I need to know which batteries are best for a possible 10Kwatt system... I can put up two 2 batteries. 11Lx8Dx12H Inside the fenderwell space.
nobody has insights?
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I am running 10,000watts.
You're running 10,000 watts and asking these noob questions?
Answers:
1. As many high output alternators as possible.
2. As many batteries as possible.
MORE IS BETTER WHEN TALKING ABOUT ELECTRICAL. IT IS THE MOST OVERLOOKED PART OF A SYSTEM. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
well I am noob at running 10krms I want to make sure I can get the proper electrical before I get that equipment. I am jumping from 3krms to 10krms. At least thats what I want to do, but if I can't then I will step it way down.
No need to step it down man. You just need multiple big alternators and a bank of batteries.
I need to know what amperage alternator I need. It has been suggested that I keep the stock and add a second high output on a secondary ciruit. I am only able to fit 4 standard size batteries in the back.
Coulda already had his answers (4) My interior dome lights are dimming with bass | DiyMobileAudio.com Car Stereo Forum
20
Cat as in animal. I had it sitting out on in the box with the box open as I grabbing some connectors from the other room as it was on the one...
14
I have not tried any Lith.Batteries yet. I am debating on that for Next years build out. deff considering
15
subzero
subzero
Chandler, AZ
subzero
    Jun 3, 2024
