High level inputs
  • 2
Bren23
Hi all. I'm Brendan, new to this forum. I've been fitting very basic installs in my cars years but always on an aftermarket head unit so used phono cables. I currently have a 2015 Aygo which has a factory stereo with rev camera (not needed on a matchbox car I know), Bluetooth and all that good stuff. I do like the head unit so was wanting to put in a 5 channel amp to run 4 speakers and a sub. It only has front door speakers and tweeters in the dash, the tweeters I thought I would leave running off the HU. I was wondering if it is possible to run a 5 channel off this set up using high level to phono be converters? Apologies if this is not the correct terminology... If not, what would be the best way to wire this up, if possible. Thanks in advance.
Yes, it is possible. Most 4+ channel amps have the option to use just one pair of rcas to supply all of it's channels. Since your car only has front stage, those speakers should be receiving a full spectrum, with a simple capacitor protecting the twweter. I believe you will be able to use an simple Line Output Converter (LOC). Some amps come with a built in high level input. That is where the radio speaker outputs will be connected to, instead of an LOC.
Now a heads up. Many have had trouble with simple LOCs, so I suggest an economic one of around usd $20-$30. If it works, awesome. If not, you will need an Digital Signal Processor (DSP). But we will delve into that if need be. Keep us posted.
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
426
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
407
You need to set the high pass filter for your 6.5" speakers. I wouldn't run anything lower than 80hz. 100hz would be alot safer. Adding a...
Bren23
Bren23
Grimsby
Bren23
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
