Hifonics BX1500D help!
AudioRiot
My amp keeps going into protect i was listening to it for a good 2 hours almost all the way up then it turned off and then turned back on turned off came bak on. then i just figured it was overheating and that it needed to cool so i left it set for bout an hour or 2, cam bak to listen to it and worked for bout 5 min. then bak to protect. Do u think its a wireing problem i have l7s and i dont want to take my subs out and put them bak in becouse they wont be in secure becouse the speaker holes will already b there ya know.
Thankyou
check the ground...did you set the gain rite?...make sure you dont turn the bass boost up(well turn the bass boost up first then gain)...thats how i blew my 1500d...
the amp lights up and everyting becouse at first i thought it was ground or the remote but it wasnt its getting power but not putting out cuz it goes on protect. but it will b on protect and like 30mins later it will turn on for like a minute and then turn back off
What locatioon do you have the amp? Is it getting any ventilation? My 4 channel planet audio amp cut out when I was on a 3 hr ride home in 100 degree temps. I installed a fan in the amp compartment that I made and haven't had it go into protect mode since.
thats very possible, thats what my friends said that i was with. but sence ive had the seats down in the back so its getting nice temparure of the car because i have it on the back of my box
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
163
AudioRiot
AudioRiot
West Palm Beach
AudioRiot
    Jun 1, 2024
    May 31, 2024
