Hifonics amps any good?
Well, depending on what sub you have, i'd go with a Hifonics Brutus bx1500d, because it can put out 500w@4ohm, and later on, if you decide to upgrade, you have 1kw@2ohm and 1500w@1ohm to work with.
The Nemesis are a lower series of amps than the Brutus.
Just a lower series not lower quality? Is the Nemesis series older than the Brutus and would I notice a difference between the two when playing?
Thanks!
I have a NX880 right now in my truck. I have not had a problem with it overheating once.
I amp is about 3 years old. Its a very well built amp. Keep in mind it does now use multiple smaller maxi fuses. I uses ONE LARGE 60-80Amp fuse.
WHen i blew a fuse (I was building stupid when wiring it up) i couldnt find this anywhere local i had to buy them online.
I was curious to know if anyone knows anything about the hifonics eagle series? I have tried searching the web and i can't find any reviews on it and i went to hifonics webpage and i couldn't get any info there. If anyone can tell me about there warrior eagle model im looking into getting the 50x4 for my inside speakers next month thanks.
It was at sounddomain but usually they have reviews on there products but this one had no reviews. Which i thought was odd saying its the cheapest 4 channel amp but its by hifonics i figured it would be a good amp but i just hate to spend money on a amp that has no reviews by anyone on the net //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
326
454Casull
454Casull
Toronto, ON
TwistedVisions
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
