Hifonics amp going into protect mode as soon as it gets any power
Melgoza96
Hi everyone I have a hifonics gemini elite 1900 watt amp pushing 2 10" kicker CVR's yes I know it's way to much power gains are not all the way up however whenever the amp gets any power wether the truck is in accessory or ON the amp goes straight to protection mode I've re ran all the wires changed all the fuses and still nothing I also checked with a test light and noticed even tho the amp is on (in protect mode) it's not sending power to the channel outputs is this a normal thing for protect mode ? Any thought on what might cause it to go into protect? Thanks
Which CVR's do you have, D4 or D2?
Even If dual 2 paralleled (.5) I'd think it wouldn't go into immediate protect but you never know.
It is a Hifonics after all... Idk if I'd believe any ratings regarding power output btw.
That amp is probably well within the power limits of those subs and if wired to 1ohm it's probably a different issue, but if you have dual 2 coils all paralleled (.5) I'd lean towards that 1st of all as being the issue.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Melgoza96
Melgoza96
Tucson, AZ
Inverted
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
