Hifonics 1500d vs Sundown 1500d
yes... you would see a difference. IIRC those BX1500ds only put out around 900 watts and the Sundown has been tested to make over 2000 watts with upgraded electrical.
I dont think this was really helpful to type.
The BX series is over rated but not by 600watts. Ive sseen them do 1300. Not to mention you then compare it to a sundown run on a higher electrical?
Running both of the same car and stock electrical there is a difference Likely 500 watts or so difference at least. But dont grab a mystical # about a hifonics amp and then go overboard on sundown.
I have sundown amps and a ton of hifonics equipment. I do prefer sundown tho and I think it would be worth the upgrade.
sundown>hifonics '
hifonics is a great budget amp but sundown will always outperform
unless u go wit some of the more expensive models which negates the purpose
Hifonics is better than Sundown when comparing the XXV line. However, Sundown is actually proven and has great technology. Id def choose the Sundown.
ive ran both the hifonics bx1500d and the saz1500, and yes the sundown is better , but unless your getting one for one hell of a deal or just have cash to burn, i would save my money... yes i think it would put out more power, and last longer, and the customer service is there... but if your hifonics is working and your pleased with it, why fix something thats not broken?
The real answer here is no, you will likely not see much of a difference. If the hifonics is truly overrated by a few hundred watts, you're still only talking a minimal difference when in the 1500w range.
I doubt you'd see an improvement worth the investment.
how about upgrading to the Hifonics BXi2607D. its rated at 2600. my only hard coming of all this is i plan to add another 15" and i would like a second amp. unfortunately the bx1500d is no longer being made. plus it doesnt seem like enough power.
rain377
rain377
Detroit, Michigan
groundpound4200
