Amp help!
MacDre
Alright, so I have a 1994 tercel and the audio system is completely stock (crap). So over the past few weeks I've been buying stuff for a new system. So far I have a new alpine deck, 4" alpine speakers (front doors), and 6.5" alpine speakers (rear). So now I've hit a snag. I'm not sure if I want two 10" subs or two 8" subs. I want the 10's but I don't want my car to rattle down the street lol.
But I've found what I think is a pretty good deal and I can get two Alpine SWS-1023D for about $160.
The specs are as follows:
* 900 watts max output
* 300 watts RMS (150 per coil)
* 10" sub
* Extra reinforced pulp cone with aluminum finish (Rev-lar made for long lasting sub)
* 3/4" rubber surrounds
* dual 2 ohm voice coils (you can run at 1 or 4 ohms) (2 subs @ 2 ohm or .5 ohm)
* stamped steel basket
* frequency response 30-700 Hz
* sensitivity 84 dB
* top-mount depth 4 3/8"
* sealed box volume: 0.65-1.5 cubic feet
* ported box volume: 1.0-1.75 cubic feet
So my question is this should I get those two 10's for a 1994 tercel, AND PLEASE recommend amps to power the things.
Alright I've decided on the 10's
So I need a amp that will power these specs x2 (two 10's)
* 10" sub
* sensitivity 84 dB
Please leave info on the specs I will want to look for on a amp to power this...
Would these specs run the two 10's?
- 200W x 1 at 4ohms [20-200kHz 0.5% THD] - 400W x 1 at 2ohms [100Hz 0.5% THD]
- 500W x 1 at 1ohm [100hz 1% THD]
god no, sensitvity 84 db???you'd better get a powerful amp. if you want to go fairly cheap pioneer has some slam'ing 10's. look at the sens. db, a spkr at 94 sensitivity will be 2x as loud as 1 at 84 given the same wattage
My uncle used to work for audio express so he has tons of crap. He's going to hook me up with two 12" Alpine Type R's. And a bad *** Kenwood Amp. =)
i think your a tool that doesnt know what he wants ..... why dont you ask your uncle all your audio questions?
MacDre
MacDre
LA, CA
2Tone
