HID lights shut off?? plz help!
Only The Best
texas
so I just installed a 55 watt 6k hid lights in my truck All of the wires were connected as said in the user manual… the lights look perfectly fine when I turn them on and the truck Is turned off…. But when I turn the truck on the lights flicker out and then start to go ape sh*t… maybe I need to wire it straight to the battery or the original wire isn’t thick enough?? Let me know… I’d really like to get it fixed quick!!
thank you all for your help
2005 dodge ram 1500... its connected into the wire harness... idk if it requires a relay... I know that when I turned it on with my truck started it shorted out my cabin lights //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif and I couldn't get them to come back on. but when I turned the truck off the lights worked just fine?????
Maybe the lights are getting too much power?
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
745
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
Only The Best
Only The Best
texas
Only The Best
    May 18, 2024
    May 16, 2024
