hi level input
High level inputs are inputs that directly accept the amplified output from your headunit. They are for use when your headunit doesn't have any RCA output (i.e. like a stock headunit). You just tap into the speaker outputs and run them directly into the high level inputs rather than having to purchase and install a Line Out Convertor.
If your headunit does have RCA outputs, there is no reason to use the high level input.
rocky 59
rocky 59
St louis, mo
jgarcia9102
michigan born
    May 14, 2026
michigan born
    May 14, 2026
