Different class amps?
so class D is the better out of them or am i wrong. Also, wut amp do u recommend with atleast 3000w peak
Except for Class C or B (which are inferior for audio amplification apps), it comes down to the intended use as to what's ultimately better. Class D, T, G, etc... amps are used for monoblock amps for subwoofers commonly because they're relatively efficient for the amount of power generated. You could use Class A/B for subwoofers, but at the cost of a higher current demand for the same amount of output power. And Class A...well, you wouldn't want to use it in a vehicle, but it excels in the narrow application it does work for //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Snap up that Tantrum then //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It'll give you at least 700W RMS per driver @ 4 ohms, and give you impedance flexibility for future setups.
I thought I read the mods don't help anyone? What are you guys doing in here? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
To spaz... you do realize that "4000" watt amp will do nowhere near that, right?
do no where near wut. the amps im gettin will only peak at 3000w total
That Lanzar Vibe is somewhat overrated, so you won't get 4kW before the onset of clipping. Not like you really need anywhere near that much power to begin with.
If you can afford to spend $500 on an amp, get that Tantrum for a little over $300, and use the money you saved to buy more stuff for your install //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
spaz0055
spaz0055
Cumming, GA
spaz0055
michigan born
    May 14, 2026
michigan born
    May 14, 2026
