Hi from Greece!! Help me please..
pica
Hello everybody. This is Gus from Greece. I own a kia picanto 2007 and i want your help. Fisrt of all, forgive if i make mistakes, i can't speak enhlish fluency ..
Well, i put on my car two amplifiers. The first one is a 4channel blaunpunkt gta 480 which is connected with my subwoofer signat onyx 112 and plays only the sub..
The other amplifier is a 2channel axton C400, or something like that (i can't remember well) and this one is connected with focal 130A1 speakers. I want to tell me how i should setup my 4 channel amplifier so that it will not be damaged or my subwoofer won't be damaged too.
So, i want you to tell me how to set the input sensitivity, the bass boost, the frequences etc. Please tell me rates. For example, the dbs goes from 0-12, the frequency from 50Hz-250Hz and the gain from 0.3V-8V.. Which are the "right" rates?
These are gta's 480 technical details:
GTA 480
Max. Total Power @ 4 Ohms 850 Watts
Max. Power at 4 Ohms 4 x 160 / 2 x 425 Watts
Max. Power at 2 Ohms 4 x 210 Watts
RMS Power at 4 Ohms 4 x 75 / 2 x 210 Watts
RMS Power at 2 Ohms 4 x 105 Watts
Number of channels 4/3/2
Frequency response 10 - 35,000 Hz
Signal to noise ratio > 95 dBA
Distortion factor (@ full RMS Power)
Input impedance > 10 kOhm
Attenuation factor (@ 4 Ohms) > 100
Input sensitivity 0,3 - 8 V
Input sensitivity Direct Aux Input 300 mV
Stability 2 Ohms (4 Ohms bridged)
Lowpass 50 - 250 Hz (12dB/Octave)
Highpass 50 - 250 Hz (12dB/Octave)
Bass Boost 0 - 12dB @ 45 Hz
Inputs 4 x Cinch/RCA gold plated, 4 x HighLevel, 2 x Direct Aux Input via 3.5 mm phone jack
Outputs 4 x loud speakers
Dimensions (w x h x d) 352,5 x 53 x 268,5 mm
and these are the technical details for the sub:
System single sealed box
Diameter 1x12"
Continuous powerhandling 150 Watts
Maximum power handling 300 Watts
Nominal impedance 4 Ohms
Sensitivity 91dB/w/m
Overall dimensions 410x384x314/204
Box volume 26 liters
Terminals gold-plated push
Woofer basket stamped steel powdercoated
Voice coil 25mm aluminum 4-layer
Well???
It is quite inefficient to run that sub, needing only 150 watts, off a 4-channel amp. You really need to look at the RMS ratings of the subs and amp you are connecting them to. My advice would be to either get a smaller amp, or get a second sub. What are the specs for the Axton amp?
If however, you want to just keep the equipment you have, bridge 2 channels of your 4 channel:
Sub + to Amp channel 1 +
Sub - to Amp channel 2 -
Bass boost set to 0db's
Gain set low
crossover around 80hz
I've put the sub with the blaunpunkt first and after months the other set and that's the reason they are connected like this. The amplifier is bridged (Channel 3 and 4). The axton amplifier is 2X100rms at 4ohms. When you tell gain low.. how low for example?
My headunit is sony GTX410U
run your speakers off the 4-channel and the sub off your two cahnnel if thats the case. Do you know if that amp is bridgable? What kind of power would it put out in that case.
To make the gain lower, turn towards 3v or lower if possible
stocker08 if you mean the 4channel amplifier yes it's bridgable.. 2X210rms in this case. I'm afraid of my headunit and subwoofer's life!
pica
pica
Greece
stocker08
BP1Fanatic
BP1Fanatic
